Hermes
Webrax Multi-Clean 115mm Angle Grinder Discs
SKU: 701320
€13,00
  • Multi-Clean, suitable for many applications and materials
  • Open structure that will not clog
  • Minimal heat build up
Suitable for 115mm angle grinders, these discs are called Multi-Clean cleaning discs and are part of the Webrax range of products from Hermes designed to do just as they say. With a grain of silicon carbide on an abrasive web on a fibreglass backing pad they are suitable for removing rust, paint, lacquer, primer and filler as well as cleaning weld seams, sealant and adhesive residues and cleaning concrete surfaces. They have an anti-clog structure with minimal heat build up for long life and consistent surface finish. Available size 115mm, 22mm bore.
Disc Diameter 115 mm
Web Attribute Set Angle Grinder Discs
EAN Barcode 4045191587677
