The JSP Force
Using extensive independent research into human face shapes, JSP has been able to refine the design for a comfortable fit with an effective face seal. Made from a durable thermoplastic rubber, the mask will fit most face shapes. The 5-point suspension harness and quick release buckles make it easy to adjust. The mask moulds to the shape of the face and padding provides extra comfort.
The optical Class 1 visor conforms to EN166.B impact protection (tested with a 6mm steel ball bearing travelling at 270mph). The completely clear panoramic visor maximises light levels within the mask giving optimum visibility. The visor has anti-mist and anti-scratch coating as standard and comes complete with a replaceable peel-off visor protector.
The unique Typhoon
The Force
Disassembly, cleaning and maintenance are effortless with replacement parts available if necessary. JSP Force 10 respirators are reusable. For convenience, they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.
Conforms to EN140 optical class 1 EN166 B (impact) EN 136 (class 3)
An initial face fit test is recommended.
Please note as this is a Health and Safety respiratory item, we cannot accept items for a refund once the packaging seal is broken and item has been worn.
