Install drawer slides quickly and accurately, without measuring and marking with the Drawer Slide Jig. Designed to ensure perfectly aligned, smooth-running drawers, this easy-to-use jig holds slides securely in position while you drill mounting holes in the cabinet and attach slides to the drawer box.
Taking the guesswork out of installing drawer slides, the jig indexes to the cabinet face frame - or cabinet side on frameless units - to guarantee level, straight and consistent slide positioning. Its brackets clamp outward, supporting the drawer as you secure the slide to the drawer box. Built-in tabs support the slide inside the cabinet.
Compatible with most drawer slide types, including ball-bearing, epoxy-coated and undermount slides, the jig delivers reliable, repeatable results. Ideal for cabinet upgrades, furniture projects or full kitchen installations, it’s intuitive for beginners yet robust enough for professional use.
Install one drawer or dozens with confidence - and achieve smooth, precise operation every time.
Contains 2 x brackets, 4 x upper/lower sliders.
