This drill jig is an alignment tool for the Clamex S-20 connectors, that can be applied on both the inner and outer sides of a workpiece. It allows for the drilling of 6mm holes that are required to lock the mechanism in place and allows for precise placement of the connector. Working especially well on 90 and 45 degree angles, this drill jig is in a fixed position. (Note: the jig is supplied with no drill bit and no S-20 connectors).
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640348848235
