Liberon’s unique knotting solution helps to stabilise and prevent seepage from knots in resinous woods prior to painting or varnishing. Suitable for use on all types of wood, the solution dries clear and also helps to minimise the discolouration of paint finishes, and is ideal for use on pine before painting.
This product offers excellent coverage, with 250ml covering an area of 2-4 m². With a quick drying time of just 2 hours, you can efficiently complete your wood preparation projects.
To ensure the best results, make sure the surface is bare, clean, dry, and free from dust. If you plan to dye or stain the wood, do so before applying Libéron Knotting Pale. Apply one coat directly onto the knots using a high-quality, clean brush. The knotting will be touch dry in 15 minutes, but allow it to fully dry for an additional 2 hours before applying any finishes.
Coverage 8 m to 16 m per litre
Application Method Brush
Drying Time 2 hours
Clean Up Methylated Spirits
Web Attribute Set Grain Filling & Sealing
EAN Barcode 5022640002713
