Designed to make accurate machine cutting a breeze, plus help protect hands and fingers, the Microjig GRR-RIP BLOCK Smart Pushblock is an essential accessory for any woodworking workshop. Its broad gripping surface, comfortable handle and smart hook technology provide exceptional material control, helping you achieve safer, cleaner and more consistent results across a wide range of woodworking applications.
The GRR-RIP BLOCK features intelligent auto-retracting hooks that automatically lift clear of the workpiece during the cut before dropping down to grip the tail end for continuous control. When not required, the hooks can be locked in the retracted position, giving you the flexibility to adapt the pushblock to different tasks and machinery.
Its high friction, non-slip grip conforms to the contours of the workpiece, providing traction on a wide variety of materials. This secure hold helps prevent slippage and improves feeding control.
A built-in 90° flip guide provides additional support for resawing and veneer cutting on the bandsaw. It can also be used when routing beaded face frames and other profiled workpieces against a router fence, helping maintain stability and accuracy throughout the cut.
For routing applications, the GRR-RIP BLOCK offers outstanding control while keeping hands safely away from the cutter. The smart hooks can be locked in the retracted position to prevent interference with the router bit, while the included deflector/connector help shield from flying chips and debris during freehand routing.
The deflector/connector can also be used to join two GRR-RIP BLOCKS together, creating a larger gripping surface for handling wider workpieces and providing even greater control when working with larger material.
Suitable for use with table saws, router tables and bandsaws, the Microjig GRR-RIP BLOCK Smart Pushblock delivers enhanced safety, versatility and confidence across a wide range of workshop applications.
Overall L x W x H 228 x 158 x 63 mm
Web Attribute Set Saw Bench Accessories
EAN Barcode 815267010439
