The Narex 4 Piece Richter Butt Chisels are premium bevel edge chisels designed for precise woodworking in confined spaces. Their short, sturdy blades provide exceptional control when cutting hinge mortises, fitting hardware, trimming joints and carrying out detailed cabinet work. The ultra-thin bevelled sides are ideal for fine joinery and make it easier to reach into tight corners, while the compact design offers greater accuracy wherever space is limited.
Each chisel features a blade forged from high-quality chromium-vanadium (Cr-V) steel, cryogenically treated and tempered to at least 62 HRC for excellent edge retention and durability. Each blade is finely ground and polished for a sharp, ready-to-use cutting edge, while the polished ash hardwood handles are fitted with a solid stainless-steel ferrule and leather washer to withstand repeated mallet work. The combination of premium steel and robust construction makes these chisels equally suited to fine hand work and heavier workshop use. The set is supplied in a solid wooden case for protection and easy storage.
The Narex Richter range is the brand's premium level, combining advanced heat treatment with precision manufacturing and carefully selected materials. Designed for professional craftspeople and serious woodworkers, Richter chisels deliver outstanding cutting performance, long-lasting sharpness and the control needed for demanding joinery.
Web Attribute Set Chisel Sets
EAN Barcode 8590137538009
