Perfect for almost any small workshop, the NV 750 vacuum extractor is quiet, efficient and built to last. Specifically aimed at users of small benchtop machines and power tools, this extractor is light in weight and easily moved on it's wheeled chassis.
The 'TwinFlo' vacuum motor provides power for all tasks. The extractor has a 'Permatex' filter and a 'HepaFlo' disposable filter bag giving filtration down to 0.5 micron @ 99.95%. The drum assembly incorporates a 51mm cyclonic inlet connector for large dust/chips. A second 51mm front uses the HepaFlo bags when extracting from a machine or tool that produces dust as opposed to chips.
The accessory kit includes a 2.5 metre 51mm flexible extraction hose with a rubber expanding cuff for linking to most small workshop machines with up to 58mm dust ports. A 51mm stainless steel 'gulper' crevice tool is provided for general workshop cleaning.
This machine is the ideal solution for those requiring something portable and also to handle a large range of extraction tasks. It is robustly built in heavy gauge epoxy painted steel, and it's designed and made in England.
Filter Performance 0.9995
Overall L x W x H 450mm diameter x 650 height
Rating Trade/Professional
Corded or Cordless Corded
Max Capacity Dry 35 litre
Airflow Volume 2,500 litre/min
Sound Pressure Level LpA [Uncertainty K] 66 dB(A)
Motor Power 1,000 W
Plug Fitted UK 3 pin plug
Made in Britain Yes
Web Attribute Set Power Tool Extractors
EAN Barcode 5028965694350
