This Perform 254mm Saw Blade Package comprises of 1 x 24-tooth rip blade and 1 x 60-tooth crosscut blade. They are both Teflon coated blades, which helps to reduce heat and friction.
Bore size 30mm.
Blade Diameter 254 mm
Web Attribute Set Circular Saw Blades
EAN Barcode 5052511143191
