Perform
Perform Woodturning Chuck T04M
SKU: 113639
€110,00
  • Excellent beginner woodturning chuck
  • 88mm chuck diameter
  • Stainless steel body for corrosion resistance
  • Tommy bar design for simplicity
  • Made entirely in Axminster, UK
  • CNC precision for accuracy
The Perform Woodturning Chuck is a compact, reliable option ideal for entry-level and beginner woodturners working with smaller lathes. Precision made in Axminster, UK, it features a stainless steel body for added durability and corrosion resistance - making it a long lasting choice for those new to turning or those making smaller turned items. It is machined to exact tolerances for a perfect fit.
The 88mm chuck uses a traditional tommy bar design, operated with two stainless steel bars to tighten the chuck and adjust the jaws manually. This simple mechanism keeps the overall chuck slim, making it useful for smaller projects or delicate work, and to maximise the lathe's capabilities.
Supplied with black E Dovetail Jaws to give a stable and secure hold to your workpiece on both internal and external dovetails. These are suitable for a variety of timber shapes and sizes; a great universal jaw type. The chuck also features the quality SafetyJaw accessory mounting jaws - the edges have been modified with a slight radius, so if the jaws are extended beyond the body of the chuck, the chance of injury is minimised should hands get too close.
For woodturners starting out, this beginner woodturning chuck offers quality, control and simplicity. It is well suited to use alongside the Perform PD205WL Woodturning Lathe.
Designed, developed and made entirely in Axminster, UK for CNC accurate results. Suited to the Perform PD205WL Woodturning Lathe, the chuck spindle thread is 1 x 8 tpi.
Made in Britain Yes
Web Attribute Set Woodturning Chucks
EAN Barcode 5052511143368
