These double flute cutters are made of solid tungsten, clockwise cutting. The fishtail profile ensures cutting to the centre, allowing boring too. Usable on cast iron, hardened cast iron, steel, cast steel, brass, aluminium, and even glass, plastics and carbon fibre. One of each 1.0 - 2.0 and 3.0 mm. Shaft diameter 3mm. Supplied in a protective box.
Proxxon
PROXXON 3 Piece Tungsten Milling Cutter Set
| Web Attribute Set | Proxxon Accessories |
| EAN Barcode | 4006274271166 |
