Proxxon
Proxxon Diamond Coated Fine Cutting Disc
SKU: 113293
£12.31
£10.26 Excl. VAT
  • Cuts stoneware, ceramics, natural stone, and more
  • Ideal for precise and detailed tile treatment work
  • Provides rapid and clean results with low heat development
  • Compatible with long neck angle grinder LHW & LHW/A
Achieve precision and efficiency with our 50 mm diameter diamond-coated fine cutting disc. Compatible with the Cordless Long Neck Angle Grinder LHW/A, this accessory is ideal for tile treatment and can handle materials such as stoneware, ceramics, natural stone, artificial stone, brick, gypsum, plaster, and glass. Its low cutting speeds and low heat development make it perfect for achieving extremely thin and precise cuts without damaging your materials.
EAN Barcode 4006274281585
