Designed with model making and fine detail work in mind, this lightweight scroll saw 'ticks all the boxes' in the 'must have' list. Accurate, easy to use, variable speed, blade wear compensation / length adjustment, adjustable blade guide / hold-down, integral dust blower, dust extraction port. A surprisingly robust and generous table (160 x 160mm) is fitted with a calibrated rip fence and slide mitre fence, this surmounts a sturdy ABS base with a side door for easy access to the bottom blade clamp assembly, the whole supports the die-cast aluminium saw frame with a throat of 300mm and a simple but very effective tensioning head with integrated blower. Takes standard unpinned scroll saw blades.
Proxxon
PROXXON DS 230/E Scroll Saw
| Dust Extraction Outlet | 37 mm |
| Max Depth of Cut @ 90º | 40 mm |
| Rating | Home/Light Trade |
| Stroke Length | 7 mm |
| Table Size | 160 mm x 160 mm |
| Throat Depth | 300 mm |
| Motor Power | 85 W |
| Model | DS230E |
| Nett Weight | 3.0 kg |
| Strokes per Minute | 150 - 2,500 (var) |
| Voltage | 230 V |
| EAN Barcode | 4006274270886 |
