Proxxon
PROXXON DS 230/E Scroll Saw
SKU: 610874
£156.05
£130.04 Excl. VAT
&#149 Variable speed &#149 Blade wear compensation &#149 Integral dust blower and dust extraction port &#149 c/w calibrated rip fence and slide mitre fence
Designed with model making and fine detail work in mind, this lightweight scroll saw 'ticks all the boxes' in the 'must have' list. Accurate, easy to use, variable speed, blade wear compensation / length adjustment, adjustable blade guide / hold-down, integral dust blower, dust extraction port. A surprisingly robust and generous table (160 x 160mm) is fitted with a calibrated rip fence and slide mitre fence, this surmounts a sturdy ABS base with a side door for easy access to the bottom blade clamp assembly, the whole supports the die-cast aluminium saw frame with a throat of 300mm and a simple but very effective tensioning head with integrated blower. Takes standard unpinned scroll saw blades.
Dust Extraction Outlet 37 mm
Max Depth of Cut @ 90º 40 mm
Rating Home/Light Trade
Stroke Length 7 mm
Table Size 160 mm x 160 mm
Throat Depth 300 mm
Motor Power 85 W
Web Attribute Set 230V Scroll Saws
EAN Barcode 4006274270886
