The PROXXON FD150/E Precision Lathe is a compact metalworking lathe for facing and longitudinal turning, boring, taper turning, parting and drilling. The high maximum speed (5,000rpm) allows very small diameters to be machined. The lathe has an accurate bed made from a heavy-duty aluminium extrusion and a spindle from die-cast aluminium. It is run using a powerful, quiet running DC motor which has a two stage belt drive used in conjunction with an electronic speed control to achieve the full speed range (500-5,000rpm). The main spindle runs with precision bearings and has a continuous bore of 8.5mm.
Proxxon
PROXXON FD 150/E Precision Lathe
| Overall L x W x H | 360 mm x 150 mm x 150 mm |
| Rating | Home/Light Trade |
| Motor Power | 220 W |
| Web Attribute Set | Metal Turning Lathes |
| EAN Barcode | 4006274241503 |
