Proxxon
PROXXON KS 230 Saw
SKU: 300095
£129.05
£107.54 Excl. VAT
&#149 8mm depth of cut &#149 58 x 10mm saw blade &#149 Fully machined aluminium table &#149 Sturdy ABS base &#149 Mitre fence and rip fence &#149 34mm diameter dust extraction port
A small precise mains driven modelling saw with an 8mm depth of cut using the standard 58mm diameter blade. It has a fully machined aluminium table top some 160 x 160mm mounted on a sturdy ABS base, and comes with a mitre fence and rip fence. There are 2 blades available for different materials, the 300108 alternating set for wood and plastics and the 300109 for fine cuts. There is a 34mm diameter dust extraction port at the rear of the machine.
Dust Extraction Outlet 34 mm
Max Depth of Cut @ 90º 8 mm
Overall L x W x H 240 mm x 180 mm x 80 mm
Rating Home/Light Trade
Table Size 160 mm x 160 mm
Blade Diameter 58 mm
Motor Power 85 W
Saw Blade Speed 5,000 rpm
Web Attribute Set Proxxon Power Tools - Saws
EAN Barcode 4006274270060
