The table and arm of the PROXXON TBH drilling machine are made of die-cast aluminium. A refined, rust-proof and statically very solid material. Fittings and feeds are machined on CNC controlled machines (milled, line-bored, lathed, etc.). Practical height adjustment via toothed rack with easy to operate crank. The table features a ribbed base and milled work area with T-slots. The column is bright nickel-plated. Powerful, long life 230V permanent magnet motor. The quill is driven via a belt and three step pulleys. This yields a torque multiplication of as much as 6x at the lowest speed. Geared quill feed for exact operations runs in ball bearings. Spindle with 1/2
Proxxon
PROXXON TBH Bench Drill
| Table Size | 200 mm x 200 mm |
| Chuck Capacity | 10 mm |
| Chuck Type | keyed |
| Throat Depth | 140 mm |
| Motor Power | 300 W |
| Web Attribute Set | Proxxon Power Tools - Drills |
| EAN Barcode | 4006274281240 |
