This Roughneck® Round Shovel has a sharp serrated edge, ideal for digging in compacted ground, slicing through roots and opening bulk bags or bags of cement. Built to last, it is manufactured from heavy-duty, carbon steel with a corrosion-resistant, tumble lacquered finish. With a tubular fibreglass shaft for reduced overall weight and fitted with a soft grip, D-shaped handle for comfort in use. Treads on the blade allow for increased pressure to be applied with reduced risk of slippage. The Power Ring socket, steel-reinforced plug, provides a stronger blade to handle connection.
Specification: Blade Width: 225mm
Overall Length: 1070mm (42
