The SawStop Professional Cabinet Saw Mobile Base is an ideal solution for users who need added mobility for their machine. Designed for occasional movement, this built-in base installs easily on your Professional Cabinet Saw - whether during initial setup or as an upgrade added later.
An ergonomic, one-foot operation mechanically lifts the saw in a single smooth motion. When disengaged, the saw rests firmly and directly on the floor for maximum stability. Two fixed direction, 360° swivel casters allow for smooth, effortless movement when repositioning the saw.
Constructed from durable fully welded, 6.35mm rigid powder-coated steel, the base provides long-lasting strength and supports the saw without the need for any extension pieces.
Web Attribute Set Saw Bench Accessories
