The 90 Engraving Bit adds versatility to your engraving projects when combined with the stock 60° engraving bit that is supplied with the Origin machine. In addition to engraving in a wide variety of materials including hardwoods, acrylics, and non-ferrous metals, you can use this 90bit to chamfer edges.
Overall Length: 38mm (1.1/2)
Shank Diameter: 6.35mm (1/4)
Cutter Angle: 90°
Cutter Length: 6.35mm (1/4)
Geometry: V-bit, Engraving
Material: Solid Carbide
D = Overall Diameter 6.35 mm (1/4")
K = Cutter Angle 90°
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 6.35 mm (1/4")
