This solid carbide roughing bit allows you to makes single passes up to 20mm deep even in dense hardwood with confidence. The 8mm shank and solid carbide construction ensures stability and strength in deep passes in all wood and wood products.
Overall Length: 78 mm
Shank Diameter: 8 mm
Cutting Diameter: 5 mm
Cutter Length: 20 mm
Usable Length: 30 mm
Geometry: Upcut, Spiral, O-Flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
