Apply the self adhesive ShaperTape onto your workpiece. The Shaper Origin CNC router uses the tape’s pattern of dots to accurately track its position for precise results ShaperTape’s uniquely encoded patterns are printed using specialized production equipment, designed to ensure extremely high dimensional accuracy. ShaperTape is easy to apply with carefully selected adhesives that won’t leave residue on your material if it is removed soon after you have finished cutting.
Each roll of ST1-150 ShaperTape is 45m in length. The amount of tape required for a given project depends on the scale of the project you're working on. For reference, 45m provides ample coverage for approximately one and a half standard 1m x 2m sheets of plywood.
