Tools from Japan
Shinwa Try & Mitre Square
SKU: 510017
€16,00 €18,00 Save €2,00
  • Precisely machined stainless steel combination of 90 and 45
  • 160mm long x 100mm high
  • Metric graduations
A precisely machined combination of both 90 and 45 in stainless steel. The base is 160mm long and the height 100mm. A scale is provided in metric graduations on both the 90 edge and the 45 edge. Both scales are set to measure the vertical distance for convenience when laying out a workpiece.
Size 160mm x 100mm
Metric or Imperial Metric
Web Attribute Set Mitre Squares
EAN Barcode 4960910327405
