Get everything you need to keep edge tools razor sharp at home or in the workshop with the Tormek HTK‑1006 Hand Tool Kit. Designed to work with your Tormek water‑cooled sharpening system, this comprehensive set covers the majority of everyday hand tools - making it an ideal choice for keen DIYers, woodworkers and gardeners alike.
Inside you’ll find six purpose‑built jigs that make sharpening fast, consistent and safe. For knives, the KJ‑45 Centring Knife Jig handles everything from kitchen to outdoor blades (even lawnmower blades), while the KJ‑140 Wide Centring Knife Jig adds extra clamping stability for long, flexible filleting knives so you get an even bevel end‑to‑end. The SVM‑00 Small Knife Holder pairs with the KJ‑45 to take care of your tiniest pen or craft knives. Beyond blades, the SC‑60 Scissors Jig restores a crisp cutting edge (often sharper than new) while the AX‑40 Axe Jig lets you choose concave, flat or convex bevels on straight or rounded edges for safer, more efficient chopping. Rounding things off, the SVS‑38 Short Tool Jig covers compact hand tools such as small carving chisels, gouges and even flathead screwdrivers. Compatible with Tormek machines, each jig is engineered to hold the tool securely so you can set the angle, sharpen with confidence and repeat results every time.
Everything packs neatly into the robust TC‑800 Tormek Case with the tailored HTK‑00 Storage Tray to keep each jig protected and easy to find. A smart leather handle makes it comfortable to carry, the sliding lid keeps contents in place, and the durable EPP tray material is made to last—ideal for the bench, van or shed. The case is also stackable, so it integrates cleanly if you’re building out your sharpening setup.
Supplied with: TC‑800 Tormek Case, HTK‑00 Storage Tray, KJ‑45 Centring Knife Jig, KJ‑140 Wide Centring Knife Jig, SVM‑00 Small Knife Holder, SC‑60 Scissors Jig, AX‑40 Axe Jig, SVS‑38 Short Tool Jig.
2-year warranty
