Tormek
Tormek KJ-140 Wide Centering Knife Jig
SKU: 108651
€62,00
  • Get sharp and get even
  • Fits Tormek T‐4 and T‐8 machines, and older models
  • For sharpening longer knives and thin filleting type knives
  • Symmetrical bevels with the same angle on both sides
  • Adjustable to suit different blade thicknesses
  • Zinc‐cast clamps and fibreglass‐reinforced composite stops
Get sharp and get even with the Tormek KJ-140 Centring Knife Jig. It works with both Tormek T‐4 and Tormek T‐8 machines, as well as older models.
Using the KJ-140 you can achieve symmetrical bevels with the same angle on both sides of your knife. This well-balanced jig provides extra stability when sharpening longer knives or those with long, flexible blades such as filleting knives.
Restore the blade to its original edge angle or choose the angle you prefer. The jig rests freely onto the Universal Support so you can follow the curve of the bladel. Because the KJ‐140 Wide Centering Knife Jig is positioned with the stop resting freely against the universal support, you are able to follow the shapes of the knife, always guided by the universal support as a reference point. This makes it possible to sharpen knives with
different blade shapes, from fillet knives to butcher's knives and classic chef's knives.
The KJ-140 features an extra stop for tall knives, such as cleavers. You can even put a slightly convex edge on a knife by moving between the two stops.
In common with all Tormek jigs the KJ-140 is robust with zinc‐cast clamps and fibreglass‐reinforced composite stops.
Note the KJ-140 is not compatible with the SVM‐00 Small Knife Holder, which requires the KJ-45.
Web Attribute Set Grinding Jigs
EAN Barcode 7392485005087
