Tormek
Tormek KSK-106 Knife Sharpening Kit
SKU: 114344
€315,00
  • Complete knife sharpening system for Tormek water-cooled machines
  • Compatible with most knife types
  • Supports edge leading, edge trailing, deburring, honing and more
  • Includes various accessories to achieve excellent results
  • Supplied in a TC-800 case with storage tray
The Tormek KSK-106 Knife Sharpening Kit gives you everything you need to sharpen knives accurately and consistently using your Tormek water-cooled system. It removes the guesswork by combining the key jigs and accessories required to handle most knives, from small blades to large kitchen knives.
The kit supports edge leading and edge trailing, along with controlled deburring, honing and polishing, so you can achieve a clean edge every time. It works with concave, flat and convex bevels, giving you flexibility across different knife types.
Included are various accessories including KJ-45 Centering Knife Jig. This jig fits the majority of knives and automatically centres the blade for an even bevel on both sides. Simply flip the knife to maintain an even angle. Two stops ensure you can sharpen the tallest of blades, while allowing controlled sharpening of convex bevels. For longer, flexible blades, the KJ-140 Wide Centering Jig adds extra stability to keep results consistent. For knives with blades too small for the KJ-45 Centering Knife Jig, the SVM-00 Small Knife Holder is included.
Additionally, the MB-102 multi base expands what your machine can do. It allows sharpening on the flat side of diamond wheels for a flat bevel and gives you better control for edge trailing, deburring and honing.
Finally, the KS-123 angle setter helps you set the correct angle quickly, while the edge marker and loupe let you check your progress as you work.
All components are supplied in the TC-800 case with the KSK-00 Storage Tray. The case is made of a durable plastic material and has a sliding lid that keeps everything in place. It is stackable and keeps everything organised and easy to find, whether in the workshop or at home. The storage tray is made of EPP, a durable material perfect for storing your jigs for many years to come.
Contents includes: TC-800 Tormek Case, KSK-00 Storage Tray for Knife Sharpening Kit, KJ-45 Centering Knife Jig, KJ-140 Wide Centering Knife Jig, SVM-00 Small Knife Holder, KS-123 Knife Angle Setter, MB-102 Multi Base, EM-15 Edge Marker, CU-8 Edge Loupe and one pack of five adhesive Tormek bandages.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485007319
