Tormek
Tormek MSK-250 EzyLock Main Shaft Kit for T-8 & T-7
SKU: 211102
€60,00
  • Shaft, washer are all made of stainless steel
  • Stainless steel Ezylock nut
  • EzyLock makes it very easy to change grindstones
  • Kit includes: Shaft, EzyLock Nut, Nylon bearings, cross pin, stone washer and drive wheel washer
  • MSK-250 fits the T-8 and other 250mm Tormek machines
The new Tormek EzyLock shaft kit includes a self-tightening knob to secure the grindstone. No tools are required and you don’t need to exert any pressure on the nut to secure the grindstone. EzyLock makes it very easy to change grindstones, from the standard aluminium oxide to either of the specialty stones. The shaft and washer are made of stainless steel. The nut is also stainless steel. The kit includes an EzyLock Shaft, EzyLock Nut, two replacement nylon bearings, cross pin, stone washer and drive wheel washer. The MSK-250 fits the T-7, Tormek 2000 and any 250mm motorized Tormek (pre-95 models require modification).
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485001232
