Tormek
Tormek RB-180 Rotating Base
SKU: 952887
€58,00
  • Simple to switch from sharpening to honing on the leather wheel
  • Rotate your machine 180, locks fo stability
  • Low profile; minimal effect on working height
  • Rubber feet ensure it remains steady during sharpening
  • Can be mounted on all Tormek models new and old
  • Design allows for easy cleaning
The RB-180 Rotating Base adds an extra level of convenience to the sharpening workflow. Designed to fit all Tormek models, it allows the machine to be rotated a full 180 degrees in one smooth movement and then locked securely for complete stability. It makes it easy to alternate between sharpening and honing or sharpening towards or away from the edge, making switching quicker and more intuitive and improving the overall efficiency of the system.
The RB-180’s low-profile design ensures the working height remains comfortable, while its stable rubber feet keep the machine firmly in place during use. Its layout also makes the base easy to clean, helping to maintain a tidy and organised sharpening station. Including the RB-180 with the T-8 Original creates a noticeably smoother experience, especially for users who frequently move between grinding and honing.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485006145
