Tormek
Tormek RM-533 Rubber Mat
SKU: 507245
€60,00
  • A waterproof and non-slip surface
  • Raised rim helps to retain water
  • Ultra heavy duty, protects any work surface
Suitable for use with all Tormek machines. The Tormek RM-533 Rubber Mat gives you a waterproof, non-slip surface. The raised rim will retain any water spillage. 533 × 343mm.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485006176
