Tormek
Tormek SG-200 Original Grindstone - 200mm
SKU: 910078
€120,00
  • Smooth surface finish
  • Cuts all types of tools & steel qualities including HSS
  • 200mm diameter wheel, 220 grit
  • Fits Tormek T-4 and previous Tormek models with a 200 mm stone diameter.
The Tormek Original Grindstone has evolved over the years to offer the best combination of efficient steel removal, smooth surface finish and a long life. This stone efficiently cuts all types of tools and steel qualities including HSS. 200mm diameter wheel, 220 grit. Fits Tormek T-4 and previous Tormek models with a 200 mm stone diameter.
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 7392485001126
