This unique turning tool setter enables exact replication of the edge on bowl and spindle gouges as well as on flat and oval skews with a straight or a curved edge. The setter works with the Gouge Jig SVD-186 and the Multi-Jig SVS-50. The strength of the setter is that it works irrespective of the stone diameter and always produces the same edge angle. Built-in settings give pre-determined edge geometries as recommended by experienced turners. A real time saver!
Tormek
Tormek TTS-100 Turning Tool Setter
| Web Attribute Set | Grinding Jigs |
| EAN Barcode | 7392485006060 |
