An extra Universal tool for your T-4 or T-3 support can be a very useful addition, allowing quick interchange between the horizontal and vertical mounting positions, especially if it is preferable to save a particular set up. The US-103 features a micro adjuster making for smoother and easier operation and offering an accurate method to find and replicate an edge angle. This is an excellent upgrade for an older machine. If you have an older machine, which has no Micro Adjust on the Universal Support, you can retrofit the new Universal Support with Micro Adjust, US-103. You can also use the existing Universal Support, but this is less convenient. The Universal Support with Micro Adjust is also a great advantage when using the Tormek jigs. Fits Tormek T-4 and T-3.
Tormek
Tormek US-103 Universal Support for T-3
| Web Attribute Set | Powered Sharpener Accessories |
| EAN Barcode | 7392485001201 |
