If your old water trough is worn out, simply replace it with the WT-200 Water Trough for continued efficiency. This water trough is designed to keep your water-cooled sharpening system running smoothly. It retains water in the system and cools your tool's steel, preventing it from losing its temper. Additionally, it leads away steel particles and grindstone dust, ensuring you don't breathe them in.
The WT-200 Water Trough is easy to install and is compatible with Tormek machines that have a 200 mm (7.7/8
