Trendiwax is a solid wax lubricant extends the life of the blades and drill bits by reducing the heat build-up at the cutting edges and points, suitable for cutting steel, aluminium and other non-ferrous metals. It is applied directly to the teeth of a stationary blade or drill bit tip. Comes in a 343g tube.
Trend
Trendiwax Wax Blade Lubricant
| Web Attribute Set | Lubricants & Cleaners |
| EAN Barcode | 5027654504789 |
