This is a Generation 2 quick connector for TSO parallel guide system that allows quick connection to many branded guide rails.
The connection between your parallel guides and your guide rail is critical. It needs to feel like an extension of your guide rail—while still being fast to add, remove, and reposition between cuts. The new Drop-Loc Connector delivers both. The Drop-Loc Connector combines speed, security, and convenience in one design. No time is wasted sliding it to where you need it, simply press a button on the connector and insert it at any point along the track.
The little connector may seem easy to overlook, but it’s what unlocks speed and accuracy. With Drop-Loc Connectors, you’ll spend less time setting up and more time cutting.
Universal Fit: Works with Festool, Makita, Milwaukee, Kreg, Ridgid, Powertec and Wen guide rails.
Supplied as a single Drop-Loc Connector.
Fits TSO Gen 2 Parallel Guide System
