This useful accessory will make your guide rail square even more useful. It is compatible with the GRS-16 and GRS-16PE guide rail squares. The Angle Accessory deepens the reference edge of your guide rail square, overcoming problems with workpieces with profiles such as chamfers or radii etc. The Angle Accessory deepens the reference edge of your guide rail square to 47.6mm, making it ideal when cutting kitchen worktop.
The Angle Accessory consists of two 6 inch angles and screws. This enables a pair of angles to be used with clamps, for squaring up case work during assembly and glue up.
Additional Accessories No
EAN Barcode 859448007221
