Expand your woodworking capabilities with the TSO PTR-18, part of the first precision triangle family designed to take full advantage of worktops featuring the 20mm hole pattern popularised by the FestoolⓇ MFT/3 MultiFunction Table, or your own worktable made using the UJK Parf Guide System.
Straightaway,the PTR-18 will be the most accurate triangle in your workshop, but it’s no simple triangle. Careful engineering and smart design features set the PRT-18 apart. It provides a great solution for squaring your workpiece on a 20mm hole pattern bench, verifying the accuracy of a custom-made perforated worktop, or traditional triangle duties such as angle setting on your mitre saw, marking angles, or ensuring dead-square cuts on sheet goods.
With its removable foot, this triangle literally stands on its own, to verify squareness of a cabinet interior, or to register a quick 45 angle against a reference edge. The PTR-18 is made in the USA from cast aluminum tooling plate and anodised for maximum durability.
Supplied with 2 x Edge Locating Pins, 2 x Guide Rail Squaring 25mm Tall Pins, 6 x M4 Socket Head Cap Screws and Hex wrench.
