Veritas
Blades for Veritas Nos. 4.1/2 & 6 Planes
SKU: 503970
£66.48
£55.40 Excl. VAT
  • Lapped blade, 60mm(2.3/8) wide, 3.2mm(1/8) thick
  • PM-V11 lapped to a flatness tolerance of +/-0.0127mm
Veritas blade for No. 4.1/2 and 6 planes, available in PM-V11 tool steel. This PM-V11 blade is the result of two years of research and testing by Veritas. The PM refers to a process known as powder metallurgy. It involves atomising molten metals, cooling and hardening the powder, finally heating it under pressure to form an ingot. PM-V11 is a specific mixture of metals combined into a unique alloy. The resulting steel has a very fine, uniform grain structure. It is inherently more durable than steels produced using ordinary manufacturing processes. Blades made from PM-V11 are highly resistant to dulling or damage from wear and impact. These blades can take a keen edge and hold it through extended use. PM-V11 is as easy to sharpen as A2 tool steel using water stones or other common sharpening methods. Testing showed that a PM-V11 blade edge lasts at least twice as long in use as an A2 blade. Made in Canada.
Plane Blade Type PM-V11
Bevel Angle 25 Web Attribute Set: Hand Planes
