Veritas
Veritas 4 Piece Super-Hard Milled Scraper Set
SKU: 476257
£20.98
£17.48 Excl. VAT
  • Hardened to HRC 48-52 to hold an edge longer
  • Edges are carefully milled to a square, sharp 90
  • Prepared edges save time and effort of filing and stoning
  • 50 x 150 x 0.4 & 0.6mm for fine work
  • 60 x 150 x 0.8 & 1mm for heavier stock
  • 1mm scraper suitable for paint removal
Whereas most cabinet scrapers are sheared from spring steel and hardened to HRC 38-42, these Veritas scrapers are harder (HRC 48-52) and hold an edge longer. Their edges are carefully milled to a square, sharp 90. The set includes four thicknesses: for fine work, 0.4mm(0.016) and 0.6mm(0.024) thick, each 50mm x 150mm(2 x 6); for heavier work, 0.8mm(0.032) and 1mm(0.042) thick, each 60mm x 150mm(2.3/8 x 6).
Web Attribute Set Cabinet Scrapers
