The fastest adjusting frame clamp on the market. Completely knurled for good grip, the speed-clamping nuts are designed to let you make fast adjustments, yet hold securely when you tighten them.They are cross drilled to slide easily on the rods until they come up against a corner clamp; then their threads engage. To release them, you just have to back them off a turn or two and they are then free sliding again.The speed clamp includes four corners (strong, glass-filled nylon with brass inserts), four speed clamping nuts and four 1/4
Veritas
Veritas 4-Way Speed Clamp
| Web Attribute Set | Frame Clamps |
