Specialised small joinery plane, ideal for cutting grooves, such as those used for small drawer and box bottoms. It also has the ability to cut rebates (grooves with one open side), as well as decorative beads. The compact, light weight design allows you to work closer to your projects for longer periods of time.
The Veritas Box-Makers Plough Plane features a 139.7mm (5 1/2
Large brass knurl knobs make adjustments fast and easy without the need for tools. A brass knob secures the blade from the side to ensure vertical alignment with the skate, and another holds it from the top to lock the depth setting. The depth of the groove or rebate can be easily locked in place up to a maximum of 96.5mm (3/8
Supplied with a 6.35mm (1/4
Made in Canada.
