Veritas
Veritas Metric Bevel Setter
SKU: 202376
£31.28
£26.07 Excl. VAT
  • Stainless steel
  • Allows a sliding bevel to be set at any angle from 1 to 60 in 1/2 increments
  • Can be used in conjunction with a bevel to check existing angles
  • The reverse has common dovetail and polygon angles
  • Metric Graduations
This stainless steel bevel setting tool allows a sliding bevel to be set at any angle from 1 to 60 in 1/2 increments. Similarly it can be used in conjunction with a bevel to check existing angles. The blade is 75 x 180mm, and the graduations etched for permanence. The reverse has common dovetail and polygon angles.
Web Attribute Set Sliding Bevels
