The Veritas Miniature Shooting Board shooting board combined with the Veritas Miniature Shooting Plane is perfect for the final precise squaring of small wooden parts. The combination allows you to cut close to a line and then creep up on the line, a fine shaving at a time for a perfect square. The Veritas Miniature Shooting Board can of course be used with any other miniature shooting plane with a 17mm to 18.5mm wide reference surface.
The Shooting Board is made of CNC-milled Baltic birch plywood with an extruded aluminium track and a fixed cleat. The base measures 203mm x 92mm wide. The Shooting board comes fully assembled, and requires only a minor adjustment of the track before use.
Made in Canada.
