Veritas
Veritas Plunge Base for Rotary Multi-Tools
SKU: 102163
£72.78
£60.65 Excl. VAT
  • Fits any tool with 3/4 x 12 tpi threaded collar, as standard on Dremel and others
  • Converts almost any rotary multi-tool into a miniature plunge router
  • Lock lever for continuous cuts
  • Micro-adjustable depth stop gives precise control
  • 100 x 75mm footprint, easy to position and manoeuvre
  • Aluminium with stainless steel rods and knobs
  • Made in Canada
This plunge base converts almost any rotary multi-tool into a miniature plunge router for fine detail work. The 3/4 x 12 tpi threaded collar, found as standard on Dremel and many other rotary multi-tools, screws directly into the base. It gives you precise depth control when cutting recesses for hardware or inlay, or even freehand relief carving. The 100 x 75mm footprint makes it easy to position on narrow surfaces and close to edges. One side features a cutaway giving a view of the exact position of the blade. A micro-adjustable depth stop offers very precise control over the cutting depth. As with a full size router you can plunge or use the lock lever for continuous cuts. The base has rounded grooves on either side which form a natural grip for your fingertips giving better control. Made in Canada from aluminium with stainless steel rods and knobs.
Web Attribute Set General Mini Tool Accessories
EAN Barcode 722356016961
