Veritas
Veritas PM-V11 Blade for Jack Rebate Plane
SKU: 502394
£62.98
£52.48 Excl. VAT
  • Extremely durable PM-V11 steel alloy
  • Highly wear-resistant, yet easy to sharpen
  • Blades lapped to a flatness tolerance of +/-0.0127mm
  • Made in Canada
A PM-V11 blade to fit the Jack Rebate plane, 57mm wide with a 25 bevel. More than two years of research and testing by Veritas went into PM-V11, a new steel alloy. The PM refers to a process known as powder metallurgy. It involves atomising molten metals, cooling and hardening the powder, finally heating it under pressure to form an ingot. PM-V11 is a specific mixture of metals combined into a unique alloy. The resulting steel has a very fine, uniform grain structure. It is inherently more durable than steels produced using ordinary manufacturing processes. Blades made from PM-V11 are highly resistant to dulling or damage from wear and impact. These blades can take a keen edge and hold it through extended use. PM-V11 is as easy to sharpen as A2 tool steel using water stones or other common sharpening methods. Testing showed that a PM-V11 blade edge lasts at least twice as long in use as an A2 blade. Made in Canada.
Bevel Angle 25 Web Attribute Set: Hand Plane Blades
