Veritas
Veritas Round Bench Dogs (Pair)
SKU: 475715
£26.78
£22.32 Excl. VAT
  • Solid brass; 110mm long, fits any 19mm hole
  • Face with crosshatching and 2 slope holds wood securely
  • Side spring allows easy positioning
  • Works well with Wonder Dog and Wonder Pup Clamps
  • Supplied as a pair
  • Made in Canada
The Veritas Round Bench Dogs start life as 19mm solid brass rod. Brass is non-corroding and kinder to the edges of your tools should accidental contact occur. The Dogs feature a face with crosshatching and 2 inward slope, designed to hold your work piece firmly and securely on the bench top. A side spring alllows easy adjustment for height projection and holds the Dog in place once positioned. You can use a Round Bench Dog anywhere you can drill a 19mm hole.
The dogs are 110mm (4.3/8) long. They work well in combination with Veritas Wonder Dogs or Wonder Pups. Supplied as a pair.
