The Veritas Scraping Plane is the ideal tool for final smoothing. Tear-out is virtually eliminated with the cutting action of the included scraping blade. The generous hardwood front knob and rear handle make it comfortable to use for extended periods and the large sole ensures an accurately flattened surface. The adjustable frog enables blade angles from 0 to 25, providing fine control of the cutting action. A feature unique to the scraping plane is an integral thumbscrew that bows the blade to eliminate ridges in the work surface caused by blade corners. The plane comes with a 1.4mm(0.055) high-carbon steel blade suited to this technique. Weight is 1.8kg(4lb).
Sole Length 240 mm
Nett Weight 1.8 kg (4lb)
Plane Blade Width 73 mm (2.7/8")
EAN Barcode 722356006481
