Veritas
Veritas Shaft Clamp for Dual Marking Gauge
SKU: 952932
£9.38
£7.82 Excl. VAT
  • Lock the relative position of the two rods
  • Machined to precise tolerances to prevent binding on the rods
  • 13mm long collar is made from extruded aluminium
  • Turned brass thumbscrew
  • Made in Canada
On occasions, it may be an advantage to lock the relative position of the two rods on the Veritas Dual Marking Gauge, such as when a project requires a constant mortice size, but different offsets. The shaft clamp lets you lock the relative position of the cutters while still being able to adjust the fence for offset. This allows you to preserve identical mortice or tenon sizing when joining parts of different thicknesses or when adding a reveal, since it prevents the cutter settings from shifting while the fence is being repositioned. Machined to precise tolerances to prevent binding on the rods, the 13mm long collar is made from extruded aluminium, with a turned brass thumbscrew that tightens onto the marking gauge’s steel guide rods without marring their surfaces. Made in Canada.
Web Attribute Set Marking Gauges
