Self-made or bought, shooting boards usually come with a single fixed angle, most commonly 90
An adjustable fence lets you plane at any angle up to 60
The 610mm long x 9.5mm deep shooting track fits the Veritas shooting plane and Veritas shooting sander. For other planes, the track is adjustable from 52mm to 57mm wide. Low-friction UHMW strips in the bottom of the track let the plane glide smoothly. The base is 19mm thick Baltic birch plywood, a cleat on the base registers on the edge of your bench to hold it in place. The fence is cast zinc aluminium alloy, with steel and brass fittings. The track is durable aluminium. Size 610mm x 290mm. Made for right-handed use.
