Veritas
Veritas Short-Blade Honing Guide
SKU: 108354
£56.88
£47.40 Excl. VAT
  • Problem solved, sharpen small blades
  • Foolproof guide for spokeshave and short blades
  • Blades up to 66mm wide and 6.35mm thick
Thanks to Veritas’ designers and engineers the problem we face when sharpening spokeshave, small or short blades has been solved. Spokeshave, small block plane and palm plane blades are too small for most guides. This Veritas honing guide does the trick and is simple and foolproof to set up and use. Blades up to 66mm wide are easily aligned with the guide’s registration jig. It will take blades up to 6.35mm thick and sharpen 25 or 30 bevels. The adjustable fingers on the guide hold blades of all shapes securely at the correct angle. A shim included with the guide allows you to add a 2 micro-bevel.
Made in Canada.
Web Attribute Set Honing Guides
